SkipBurney
I am getting ready to flush my 7.3 and add a coolant filter with the SCA additives in the filter. What is a good coolant mix to run in my truck. Is there a NAPA coolant I can use as I am using a NAPA 4071 filter.
I'm not for sure, but say you do a precharged coolant, then adding a charged filter may be too much. Not sure though.
I'm sure someone will chime in and correct me.
I was under the impression that you have to provide the initial SCA charge and then the filter maintains the levels. Though I am not sure about the compatabilities of different brands of SCA's? I thought I read something about not being able to mix them....but then I am a little fuzzy on the details.
Around 8 gallons - 6.5 or so if you don't pull the block plugs.
