Seekers
So what's the best option for replacing the tranny cooler lines to the radiatior? Bone yard? stealer doesn't carry them and I prob couldn't have afforded them anyway... open for any other suggestions. TIA
If you put a piece of rubber in they actually make specific hose for trans. cooler line.
Also dont use normal worm clamps Get the fuel injection hose clamps.
They hold alot better and less likley of a hose blowing off.
I agree with the hard line as much as possiable,But you have to use rubber with a Aftermarker Cooler.
How did ya do that?
When the line blows off and loose fluid No fluid No pressure No move.
What did ya do hold the Hammer down?
Not if you buy the right cooler, one with pipe or flare fittings instead of hose barbs! I use Russell Pro Flex and the proper fittings, never had a problem in probably a million miles with add on oil coolers, I put them on all my daily driver vehicles.
Russel pro flex, AN fittings and pipe fittings are a far cry from rubber hose and clamps as was being suggested. In fact there is no comparison in the kinds of pressure good hose like that can take.
Tonka, I edited the previous post as I see where you got that from. I am making dinner and was in a hurry, sorry for the confusion and you are right, there is no comparison, in function or price, but I will not use rubber line on anything like that, except for ProFlex or something similar. To me, it is worth it to not be stuck along the road. Matter of fact, my whole 6.9 fuel system is ProFlex, and yes, it was costly!
