Bad coolant leak from rear of Engine
1992camarors
Van Wert, Ohio
OK guys I have a bad leak that looks that its comming the the rear of the engine. When I start my truck the coolant almost starts to *** out the coolant very quickly. The coolant is clean and not dirty. I put brand new coolant in it a week ago. I heard there is a oil cooler that could be causing this problem?
1992camarors
Van Wert, Ohio
They are new along with completley redone heads with new freeze plugs about 2 years ago with around 10,000 miles. And the engine runs fine so I thinking it can't be the gasket. But this is not really a leak its like pouring out. Where is the oil cooler at? I think it might be that but I'm not sure?
