Avg coolant temp 6.9
JAKRANCH
Benson, Utah
I have an aftermarket coolant gauge. I have to run the truck really hard to get temps above 160. Is this a fairly average temp? Truck is t19 3.55s banks power pack. I can see it being normal just wanted to ask.
chris142
SoCal
The stat starts to open @192. If lightly loaded it should be near this. The stat is fully open @212. Its not uncommon for a working engine to hit 220-230.
Macrobb
North Idaho
But remeber, unloaded cruising is not "working the engine", especially if your timijg is good and the engine's not using a lot of fuel to maintain speed.
Temps should be in the 180-195 range and stay there. If it quickly climbs to 160(within 10 mins of driving) and stays there..chances are your gauge may be reading low.
If it's slow to climb and varies quite a bit... thermostat, most likely.
JAKRANCH
Benson, Utah
Hmm well it is a slow climb and then it is steady. Stock gauge looks normal ..... I mean it is within acceptable range. Ill have to see where the sender is mounted. Is there a way to check t stat see if its bad?
pelky350
Springfield, OR
My thermostat was stuck open on my truck, I ran at 160-170 all day. Changed thermostat now sit at 190 all day idling or driving. Warm or cold outside
chrlsful
Amherst, MA
"...a way to check t stat see if its bad?..."
I like bowl of hot H2O & thermometer, throw it in & watch 4 opening/closing
03wr250f
Hamilton/Montana
mine idling, not even on high idle will over about 10-20 minutes make its way up to 190* depending on outside air temp
Fordfan90
Idaho
Mine gets to 180 but once idling it starts going back down to 140.
Cv axle
