Hardass559
89 7.3 banks turbo
ok everything works but it shifts in to over drive way too soon. hard to shift down its like a speed sensers not working right i have a 95 bronco does the same thing. start it up no lights on the dash touch the break put it in gear let off the break the break and abs lights come on .seams like the trans is skipping third gear to i need to change the over drive butten out but im sure the abs and break lights are throwing the trans off .after your roleing just shut it off real quick and turn it back on it shifts fine till ya touch the breaks and the breaks are really grabby . locks one side up in the back probly a over adjusted break .all i did to this truck was throw a moter in it and get it inspected but the breaks are really easy to push if you hafta stop a litel faster than just touching the peddel it locks one set of duals right up idk if thats in the abs or not but hard down shifting and over up shifting is the main concern right now .
