87 Crew Cab w/ 6 doors
Hydro-idi
Lodi, California
You could damn near run right through a brick wall with that bumper lol. Really coming along nice. You make up your mind yet with the rear bumper??
inner fenders are complete, zip screws gone!
5 1/4-20 bolts now hold them in place.
still have to drill and tap the frame to hold fenders in place.
firewall has been welded up of unwanted holes.
pinch weld cut off and welded up.
waiting on my light bar to finish the bumper.
still needs 3 holes tapped for winch plate to bumper.
made 1 filler panel for under headlights.
almost time to install mock up engine and mount filters before painting..
still contemplating covers for the inside of the fenders.
got a bunch of things all mocked up for final little fab things.
hydro boost, steering needs another u-joint.
but the gasket bolts up, and nuts welded to front plate... no more sheet metal skrews!!!;Sweet
fuel, air, and coolant filters all need to be mounted.
battery boxes still need to be built.
remote terminals, winch box, horns, fuel pump & regulator mount
finish bumper
anti axle wrap device.
new fuel line and brake lines.
and the list continues.
a good days work.
Looks good in there but what's that thing on top of the engine?
its a "apparatussoshitdowngetdownintotheintakebeforeislaptheturboon" cover :D
This is the rear bumper I'll be running. in diamond plate.
Decision is to do another bed.
No flat bed
MOAR firewall work is needed.
Tired of fighting that upper lip thT always snags the exhaust housing.
Better? @laserjock
jhenegh
Truck Still Earns its Keep
Deerfield, WI
No flat bed
Make those "foothold triangles" bigger. Unless yousa got tiny little feet and never wear boots. That thing looks like a rainy-day-teaser-that-gets-you-a-busted-shin-and-knee.
X20 on the 093 firewall clearance. Took a ball pein hammer to mine
So that's an ATS kit right? Are you going to re-clock the turbo outlet at all? Seems like it's pretty tight there. Remind me what finish is on your manifold? It looks great on there.
this is the OEM 093 kit.
the one i took off my truck, its got the correct clocking for my CAC tubes.
im using it for mock up, and then maybe send it to Russ, or a SD-38, i am undecided.
may sell it if deemed not needed.
no ball peen hammers for me lol, ill be cutting and welding it up, then re-seamsealing it.
may even go as far as welding up that whole seam.
but that wont happen till i pull the mock up engine.
the intake on this engine is just a rattle can paint.
again, this engine is in just for mock up reasons.
wanna finish exhaust, fuel, air, coolant, paint everything and get it up to running status before i put the shiny engine in.
when made in diamond plate, it will have more grip.
i do wear steel toes everyday, and the one he made for his SD, wasnt an issue using it for a step.
ntjapkes
