this is the one im gonna get long as its good its the stant i can get it at advanced auto
Since you insist on getting a t'stat other than a Motorcraft, NAPA has this one ( T'stat 385-190 and Gasket C24551). Also, CHECK YOUR BOTTOM RAD HOSE TO MAKE SURE IT HAS THE SPRING IN IT. iF THE SPRING IS NOT THERE THEN IT WILL COLLAPASE AND THE WP CANNOT CIRCULATE THE COOLANT, resulting in HOT HEADS making steam pressureizing the system. Just squeeze the hose and you can feel the spring if it's there.
