Your engine is from an F800 Ford. There are gobs of those out there and they make ford conversions easier. The mid mount ac bracket and AC compressor you have there is worth what you paid for the engine.
You will need a dodge pan and pickup tube/dipstick. Yes, you can flip the ford pan backwards, but it holds 5 gallons. In a pickup the engine will never get up to temp with 5 gallons of oil. Plus the 5 gallon pan won't clear your crossmember.
You'll need a dodge or 4BT fan hub if you plan to run a mechanical fan.
A 5.9 Cummins will start on the first revolution with one battery and no grid heater down to single digits. I have roll started (alt died) the 4BT cold in my 71 below 20 degrees within 10 feet on level ground pushing by myself backwards, hopping in and popping the clutch in reverse. These engines start very easily if the valves are good and timing is advanced appropriately.
Just a word of caution, be leary of the medium duty 5.9 Cummins motors. They may go a million miles in a didge, but at 26K pounds and crappy fleet maintenance they're very lucky to see 200K. I've bought many, many of those F800 12 valves with around 150K on them. I paid scrap for them and they weren't worth much more. My advice is either toss it in and hope for the best or compression test it, run and check it for blowby, pull the head and check the bores/valve seats and surfaces for flatness. A 12 valve head on a 230HP engine in a 26K chassis is done by 200K. Also, check the cam lobes when you have the pan off. Poor maintenance will really show on the valve train, mostly the cam lobes and valvestem tips.
