2500 to 3500 hubs
gwhammy
mo
What is the difference in 2500 and 3500 front ends. Is it just a spacer or do they use complete different hub and bearings. Does someone make a bolt on spacer to put one ton wheels on the frontend of a 2500?
Stoked
I once looked into converting a 2500 to a dually. The parts guy at a dealer told me that I would have to change a bunch of stuff in the frontend. I can't see any difference between the two, except for the spacer. You could buy a set of those from the parts department or probably from a salvage yard. www.performancewheel.com sells spacers (up to 4" I think) that MAY work on the front. You would also need spacers for the back. I believe the dually axle is actually wider.
ofcourse
1% r
Fed Way, WA
So, can you remove the front spacers and run 2500 wheels on the front? This would allow wider tires up front.
TC
PADIESEL
HIBBS,PA
Unless dodge is diferant than ford the front axle should be diferant the one ton should have a dana 70 or 80 depending on date builds...
ofcourse
1% r
Fed Way, WA
I believe the 2500 and 3500 both use the Dana 60.
Does anyone know if you can remove the Hub spacers and use 2500 wheels on the front of a Dually?
TC
dieselmainiac
