1969 F-250 7.3l IDI swap
that one even looks like you can mount the 92-97 master and slave assembly.
ihf-350
Independence MO
Well got started this morning pulling the core support to get the motor out only to find out I need a new one
i have a transport running from kali to Springfield/Lebanon, MO area departing next Sunday, I can throw a core support in the load if you can handle the pricing and the transport.
i can source the core support from a local wrecker.
ihf-350
Independence MO
No not right now structurally it is still solid but before I get her all painted a purdy I will need to replace it and worse case lmc carries it and they are only a few miles from me. Lebannon is about 2.5 Hrs.
ihf-350
Independence MO
Does anyone know what the difference between a 1970 and 1969 as far as a body lift would go. Like maybe the steering is different or idk I can get a body lift kit for a 70 but I can't find one for a 69 just replacement bushings.
ihf-350
Independence MO
Has anybody ever heard of making our motors a front oil sump. The pan fits both ways I just tried I would only have to make a relief for the dip stick and redo the pick up tube.
homelessduck
I believe the IH trucks and buses were front sump. These engines were designed to be used either way.
