I'm sorry, was this a trick question? I heard somewhere that a bronco tank could be swapped into therear tank position in our trucks for increased fuel capacity.
Yea I knew why you were asking. The answer is NOTHING! Heck, it's still got a little electric fuel pump in it feeding the Holley Red. No changes needed. As long as the Bronco was an EFI, it already has a fuel return even. I believe the actual capacity is 38 Gal.
Okay, next question. If I go with a bronco tank, I'm sure I'll lose my spare tire carrier, but what about my reciever hitch? Will the bronco tank clear a reciever?
