ZD1A versus ZD9 GP?
RLDSL
Diesel fuel abuser
Arkansas
If you are using a manual button to trigger them, it should be a simple matter of rigging up a set of adapters to work with the round ends. Just get a box of male blade connectors and a box of female bullet connectors and some wire the same gauge as your harness and seal the connectors to the wire with some heat shrink tubing ( or get the fancy connectors that have it built in ) and make up some little adapter pigtails to plug in to your harness, that way you can remove the adapters if you get the original type plugs next time ;Sweet
RLDSL
Diesel fuel abuser
Arkansas
If condition is questionable, before you try to start, get a can of Aero Kroil and soak the threads at least overnight before starting and if one doesn't want to come out, STOP< you will need a set of these critters To help remove the thing, and it will take a few days, but they can be removed safely without having to pull the head.
rhkcommander
Oregon
i got some zd9's recently too, great plugs. if i saw them i would have snagged them too probably being in salem and all LOL
