KodiakForge
hey guys,
I purchased an '88 7.3 last year, which has brought me to lurking this forum and now I am need of some help. Its cooling off here in Oregon (but not cold by any means) and Im starting to notice its harder to start. Ive been having to plug it in at night to get it to start. its been a downward spiral lately where the starter went on me due to more cranking so I replaced that. Got two new batteries in it. I replaced glow plugs with motor craft zd9. ive put new glow plug relay in and replaced fuel return lines and caps. and done a fuel heater delete. i dont think i have air intrusion (based on my limited understanding and late night reading) cuz if its plugged in it starts right up in the morning but it is only in the morning that its an issue also? I noticed my wts light doesnt stay on long and relay just clicks and clicks, even if it cycles more normally its not long enough to matter. the plugs and relay are new so im feeling stumped. it did read about the two yellow wires melting in the connector plug which they were and so i broke them out and reconnected them outside of plug and tapped them up individually. they didnt seem to be corroded of have any reason to not make good contact. any help would be greatly appreciated, this is my daily driver and work truck i rely on 7 days a week. when i bought it it already had some back yard stuff done to it but it worked fine most of this first year only now im hitting some snags. im kind of at a loss as for what to try next other than maybe the manual push button thing. i know there is a lot of knowledge flying around on this forum, so thanks in advance for any and all help.
