jaluhn83
Also FYI, the banks square box kits had a different up pipe and turbo bracket for a C6 & T-19, possibly a different one for the ZF5 as well. I know a C6 will not work with a T-19 or ZF. The T-19 should fit a ZF, and I expect a ZF and T-19 would be interchangeable. Probably a C6 would work on a E4OD too. The issue if the bracket, the uppipe has a bolt bolt flange similar to the exhaust manifolds. The manual trannies have a bit of a shelf where the bellhousing comes back about 3/4" and then drops down. The C6 is a smooth drop. On C6 mounts the pipe is setup to just clear the bellhousing. As a result, it hits the manual bellhousing, and since it's right at the flange you can't really bend the pipe or get around it to make one fit.
