Which centrifuge should I buy?
towtruckdave
Resident Nutcase
Cleveland,OH-Nashville,TN
I have been filtering my WMO down to 5 microns using fuel filters. It is not enough. I am getting a buildup in my injectors. I have been running wmo through a cheap "test mule" 6.9 in my pickup. After 10-15K miles, I have learned that it works, but the suspended carbon/soot in the filtered wmo messes up my injectors. I really have not cared up to now because I have been using cheap/free parts.
Now I have no choice, I have to install my very good 7.3 IDI engine. It runs good and has a nice clean fuel system. I do not want to mess this one up.
In addition to that, I am installing a 'stroke in my 86' CCSB and I really do not want to foul up those injectors.
So what centrifuges are ya'll running and for how long.
I am convinced that a good centrifuge will pay for itself. I have already saved thousands of dollars, but I have been fouling injectors with black grit.
Anybody have several thousand miles on wmo with nice clean, properly functioning injectors still?
wmoguy
Colorado
I've got a PA Biodiesel centrifuge, I actually bought their complete system
This is the one I have: http://pabiodieselsupply.com/shop/60-gph-deluxe-oil-centrifuge-kit-p-120.html
They do just sell their Fuge if you have your own setup you want to use.
I have filtered roughly 200 gallons on mine and am extremely happy with it. I generally do about 8 passes which gets it down into the .5 or less micron range. Since filtering this way vs. with bags or other filters I have not clogged a fuel filter once (hope I didn't just jinx myself :rotflmao)
Call Joe @ PABio. He's a super nice guy to deal with. He's a bit hard to reach as this is a side venture for him, but he's very good about calling you back in the evenings.
I completely agree with you that a good filtering setup pays for itself. I spent $6800 last year in Diesel for my personal vehicle. It doesn't take very long at all to have a higher end filtering system pay for itself, even more so with the increasing fuel prices.
wmoguy
Colorado
Thanks for the info, wmoguy.
This may be a silly question, but what does the final product "look like"?
Is it still black and gooey? :confused:
not gooey at all. It's got the consistency of diesel when it's all said and done. The black is still there, it can't remove carbon
Blind Driver2
New Albany, In
I fail to see the point of a centrifuge:dunno
Filter to 5 microns, add RUL, let sit for two days. Drain off the junk at the bottom, then fill'er up!;Sweet
towtruckdave
Resident Nutcase
That is what I have been doing, but my injectors are frying my RUL in the tips, according to OLDBULL's article. For the record, I believe that is what is happening.
I can now understand why I am having problems. I run the thing HARD, pulling hills at 80mph for hours on end and pulling trailers all day. :angel:
wmoguy
Colorado
yep using filters or bags will always let particles thru. most I've seen aren't designed to stop 100% of the particles larger than X microns. Centrifuge w/ multiple passes = gets all particulates above X microns.
Its also WAY cheaper in the long run when you consider the cost of filters.
BioFarmer93
OPEC Hater
Jacksonville, Florida
Man, that's just not enough- and RUG is used to thin WVO, not WMO. WVO has lubricity to spare. I use heat, 6 passes on 0.5micron bag filters AND a centrifuge for 6 passes and still clean black gunk out of the 'fuge. I will say though, that my injectors look good- probably because I run water/**** injection and a tank of #2 every 4 or 5 tanks of WMO...
towtruckdave
Resident Nutcase
Biofarmer, do you have a pic of your setup?
Devilish
Nv
Oh, I got the pumps for you guys. Oberdorfer cast iron pump connected to a Baldor 3/4hp 120v motor. I was going to post these on ebay but I'd rather sell these to oilburner bretheren that might need them. Price is $180 + ship. I'll package 1 up this weekend so I can figure out weight.
Link to pump info: http://www.oberdorfer-pumps.com/Spec_sheets/c9941b2.pdf
I do have more than 6 of these.
