Wheel fit question....
mikepotts
Jacksboro, TN
Im heading to nashville and a guy there has some nice oem wheels i want. Im just not sure they will work. They are from a 99 up and mine is a 92 f250, i read somewhere that they can be made to work but i cant find it.... Help! ;)
They will not work directly. The 97 and older 8 lug rims are 8X6.5 (8 lugs 6.5" lug diameter) and the 99+ SuperDuty 8 lug are 8X170mm. They make adapters that you could use to make them work, but they are not a direct bolt on rim.
chris142
SoCal
My truck had 16x6 stock wheels. I found some 16x7 stock wheels in pic a part. They were on an 2001 e350 church van and bolted right on even the stock hub caps and rings fit
cpdenton
Truck needs paint.
Conway AR
Vans kept the 8x6.5 bolt pattern for a while after the superduty trucks came out And changed to the metric pattern. How long I don't remember. That would be why your swap worked so well chris142. ;Sweet
chris142
SoCal
I was running a 285 tire. When i went to buy more americas tire said they cant mount them on my 6 inch wheels any more. So i got lucky and skored the van wheels for like $60 for all 4
