whats wrong with my tach
1Turbo10
Atlanta
I have the same problem! Hope someone will post an answer. I am guessing a ground problem.
Shadetreemechanic
Monteagle, TN
Most likely your tach sensor is either bad or dirty. It is located on the timing gear cover on the front of the motor. You can try unscrewing it and cleaning any oil or gunk off the pickup. That will probably do it, but if not you can replace it.
tractorman86
Buckeye, AZ
the wires comming out of it are probably dry breaking mine did that so i pulled the harness around the front of the oil fill.
