crashnzuk
The same can be said for the US gear O/D, it can be used in either range from a stop unlike a GV. If you have a close ratio T-19, you can't split 3rd. The 3rd gear ratio is so close to direct, 3rd over is basically direct. If you want to split all gears and have it meaningful, get a wide ratio T-19 with the deep 1st and you'll have a pullin machine
Travis..
Travis..
