well, change in plans... I think :dunno
93fordturbo
La Crosse, Wi
I finally got both heads off after reefing pretty hats on them. I figure I should get them checked out and rebuilt for all the work I have done. Heads are a pain! I also bent an arp stud. So I need all new ones I guess. I guess I'm looking for advice. I will have some money coming in pretty soon, but not enough to rebuild and balance the motor. I could start on doing that, or do that after I get my Lineman job in a few months. I want the truck running, so I just thought of buying a motor that runs good and throwing it in there for the time being, plus then I would have two motors :) but idk what to do. Any advice?
Blind Driver2
New Albany, In
huh?
turbo elk
Vancouver, Wa.
If you picked up GOOD RUNNING engine then you could take your time rebuilding yours and do it right...saves alot of work.
93fordturbo
La Crosse, Wi
What's the cost of a good running motor in you're opinion? And would you get a 6.9 or a 7.3? Turbo or non Turbo
racer30
western Oregon
Try a wrecking yard maby they have a runner in a truck at the yard, Its worth more to them to sell a runner than a core. might be worth a shot.
chris142
SoCal
Guy near me has a very high milage non turbo 7.3L that was running when the driver crashed the truck and he's asking $400 for it.
Pic A Part gets about $200 for a v8, add another $50 if you get the warranty. That way if it's junk you can keep going back and getting another one till you get a good one. Seem to be plenty in the yard here to choose from
93fordturbo
La Crosse, Wi
Is pulling and replacing the motor a big deal? if it's anything like the head gaskets, idk if I even want to tackle that at this point
Hardass559
89 7.3 banks turbo
falconer/new york/usa
its not that big of a deal since youv already got the heads off your moter that will come out easy iv always pulled the radiator support to put a moter in not a big deal if you dont have rust problems
