Chuckdiesel
Well heres the deal. last night I was forced to replace my waterpump after it crapped out 5 min from home. So I just replaced the pump, hoses and t-stat while it was all apart. The t-stat is a 190 degree and after all said and done the gauge stayed at the A in normAl and so I figured it was cause of the higher degree stat. So heres the thing, I left for work today and on the way the upper radiator hose popped off the t-stat housing. I went up to auto zone up the street and got a new hose clamp cause the one there was the old one and was a old 2 wire thing. I had to add 2 gallons of coolant on top of the gallon I added in the morning to top it off. Now the truck does not heat up according to the gauge now . the needle lives between the C and the bracket under Normal and it may climb up to the N but never gets hot according to the gauge.
So what the gauge broke or the t-stat is bad or maybe theres air bubbles screwing things up. I know I took my cap off after driving for a while and left the truck running and saw no movement in the coolant. also the hoses are really hard upper and lower when pressureized is that normal. I dont want to over heat and break stuff
