Can u run water injection on a NA engine, i dont have enought money for a turbo and im going to be doin some towing soon(tractor pulling season started) i just want to have something if the temp goes up high
there is a stickey up top for the splash methonal method IIRC.
it was one of the things i looked into but a lot of kids rely on boost so u need a way around that, just like the propane kits. either its on or off for us N/As.
i found a pump i could possibly use its a FLOJET Pump im not sure if it could be used with water/methanol combination, it flows 1.5 gp max and 60 psi max, i could probaly put some kind of regulator to cut down on the flow rate
