WANTED: Wiring harness for 4-door electric windows
clifdawg
Mississippi
Looking for complete wiring harness for 4-door electric windows. And if you have a drivers door switch plate that'd be a plus!
Have the doors, just no harness.
Thanks!
good luck finding this needle in the haystack.
I scowered the U.S.A for this part.
ended up having to buy a whole truck.
Be mindful of the power locks. If you find it, there are 2 styles.
Keyless entry and non keyless entry. There is a module for the keyless you will need.
Or you'll be gutting the harness.
Don't ask me how I know lol
clifdawg
Mississippi
Thanks for the heads up. So, if I get the keyless harness I need the module for the power locks to work? Just making sure I understand.
no, you don't need it to make it work, but you will have to go in and rewire the entire door lock wiring.
just makes it easier to make them work.
keyless entry uses 3 wires for the locks to work with module.
non keyless I believe are 5 wires.
I spent 3 days infront of a manual to get mine to work.
on another note.... research and see if you can use SD wiring... 1999-2003, if they can be used, I may have one for ya.
clifdawg
Mississippi
This is something I have been wondering. SD harnesses will be a dime a dozen also, compared to OBS.
correct, very limited OBS 4 door electric, and the ones that have them wont give them up without a fight...
its wortha shot!!!
I plan on stripping my SD here soon, ill check it out if you havnt found the answer yet.
clifdawg
Mississippi
its wortha shot!!!
That'd be great to know. Meanwhile, I'll be searching and researching.
clifdawg
Mississippi
Find leeland's (added 2 more doors)
He added rear power.
Thanks. Went digging. I had seen the thread before but had not read everything about his power window setup. After taking a glance, I'm still in the same place because he had a 4-window harness from a 97. And that's what I'm looking for.
as luck would have it, I just got done talking to a old man that wanted to see my truck, he has a 95 PSD XLT with rear power windows.
the sucky part about junkyards is that they sell the door harness with the door.
Kizer
Denton, Texas
If you don't find one, I decided to sell my '91 parts truck. IDK if it had keyless entry .. tell me where to look for the module and I will. PM me with offer if you still need it.
