DONT use a hammer!!!!!!!!!!!!!!!!!!!! you can imprint the bearing inside the vac pump--and the bearing in that will go out before long--
i can tell you this is true coming from a bearing manufacturing job!
I wonder how much drag the pump puts on the motor? Since I put in hydroboost, I wondered what it would take to install an electric vac pump from a Powerstroke. It might even be cheaper than a new mechanical pump.
not enough to notice, i cant speak for all but i don't think the electric pumps are cheaper or more reliable. unless you are going hydroboost i would not recommend getting rid of the mechanical pump.
Jred..... From what I have read is the Electric Pump will not keep up with a vacuum brake booster.... you still have to run the belt driven one. I know the other guy said he had gone to hydroboost.... so he could get buy with it. If he does not have A/C I dont think he needs the pump at all, unless he has auto hubs. I believe Mel has complely removed the pump from the Moose Truck.
The SuperDuty have factory hydroboost and an elecric pump, the 6.0 pump is on the passenger fender between the batteries and the A/C housing. The SD only use vacuum for the HVAC Blend doors and the ESOF Auto/Manual Lockouts. As far as reliability the only time I have heard of a SD ele. vac pump going out is on a truck that has bad lines running to the hubs that leak, causing the pump to run all the time..... The ele. pump is on a box that acts as a storage tank and it will cycle as needed... it is not rated as constant duty.....
I have wondered if a SD hydroboost would work in the older trucks?....
