Dirtleg
To start I just installed my new Tekonsha P3 thursday. I have been waiting and waiting for the Jordan to be re-released but it has not happened. My controller tells me that I have no trailer connection with the trailer connected. All my lights work fine BTW. No brakes however.
So I start checking the wiring on the trailer. I have known there would need to be some cleanup as the breakaway switch has been bypassed and there was only 1 wire going to the battery for it. I started fooling with the connector (6 pin) and noticed everything had continuity to ground except for the center pin (aux). I then noticed that the wire going to the center pin was broken about 3 inches into the loom. So I checked for continuity on this wire and it gave me a reading at every pin.
At this point I decided to go ahead and start removing the breakaway switch battery box. The red wire coming from it was the broken center wire
? The were no other wires going into or out of the battery box. How in the hell I was getting continuity on this wire I cannot guess. I have physically looked at all the wiring under the truck and although it is quite a hack job
I cannot find any places where it's worn through. It's all run through insulators at the body points. And like I said the lights all work (including brakes and turns). Even with continuity at every pole. The only wires I couldn't visually inspect were the ones in the axle tubes for the brakes.
Is there something fundamantal I am missing here?
Now I am thinking that the way the controller works is it detects ground on the brake wire. That's how it knows if you have a trailer connected or not. Then to apply the brakes it just adds voltage as needed. So I can understand why there would be continuity to ground on this wire. But why the rest of them have continuity to ground has me baffled. Unless it's just continuity through the bulbs. I suppose that could be it.
Thoughts?
I cannot find any places where it's worn through. It's all run through insulators at the body points. And like I said the lights all work (including brakes and turns). Even with continuity at every pole. The only wires I couldn't visually inspect were the ones in the axle tubes for the brakes.Is there something fundamantal I am missing here?
Thoughts?
