Sycostang67
Scooty Puff Junior
I did some work on my 86 tonight, I had to replace the three rear injector lines on the driver side. The back one had been crossthreaded and overtightened so there was a crooked groove in the seating surface. I had to replace the two lines next to it since my spares came from a 94 IDI and were bent differently. Using all three was the only way I was able to put the line clamps back on. I also changed the glow plugs, removed 8 autolites, most of which were swollen but only one put up a fight coming out. I installed 8 new ZD-1's, now it starts without ether. Here is were it took a turn, as I am proudly watching the truck idle, it starts to become erattic. I look down and it appears the vacumn pump is leaking some kind of fluid. I guess there is a weep hole on the fuel pump and it's blowing fuel all over the vacumn pump.
I checked the oil and the level is correct and has no fuel smell to it. I was so excited, I had planned on driving it to work tomorrow. Guess I can wait a bit longer.
If that's the case I could see an erratic idle... Hmmm not sure but good luck
