Turned off running truck, immediately no horn, no lights, no power to cab
CDX825
filtration nut
Litchfield,Ohio
Check your wiring on the passenger side fender. There is one connector with a large yellow wire that feeds power to both the lighting and the ignition. Both have separate fussible links as well. All that current running through that one plug creates an issue and will kill power to the cab.
Whisp
By the Grace of God, Hohenwald Tennessee
Justin,
I wasn't aware that was the main feed. I know that wire, I gave them a cursory check and QD and Fusible Links checked OK. However, I can't rule it out as it sure could be 'downstream', I'll go give it the them all a much more detailed inspection/test.
Thanks!
Whisp
Justin ** (two stars) for the suggestion ---- Corey ** (two) for reiterating the need. Your suggestion was correct!
I would like to stress, no matter how good the connector looks from the outside, how well it performs using a multi-meter, nothing, and I mean nothing beats a through physical inspection. The wire mentioned above, connector and fusible links all tested great using a multi-meter. HOWEVER, when I separated the connector and carefully inspected it, I found the connection on the large-gauge side was deformed from heat and the blade was blackened. There was also a small bulge in the insulation from minor corrosion.
I replaced the QD with the metal innards of a crimp connector and covered it with two layers of shrink wrap. Power to the cab is just fine, starts with key etc! Now if I could get the glow-plug relay to work reliably. Time to upgrade to newer relay or go manual!
THANK YOU ALL!
Before I asked for your advice, I was at the point of letting the beast rust-away by the barn. I'm off to finish the brake / bearing & shock R&R.
Thanks again!
pastorjeep
Gatesville NC
I am glad you found it. Had the exact same symptoms on my 84 and it was the same plug and yellow wire. Lost all power to the truck cab.
bbjordan
Snow Monkey
Ashern Manitoba
Wow, it never ceases to amaze me the depth of knowledge and experience on this site.
Glad you got it figured out. :)
