White Elephant
Hey yall, i got a problem thats really got me stumped. I got a 91 idi i swapped in my truck and i cant get it to idle down low without the knocking sound that makes it sound like it aint gettin enough fuel. It runs fine at higher rpm just knocks when idleing. Ive checked all the lines and stuff for leaks, replaced the fuel filter, the housing for the filter (cause i thought it looked wet), i just put in some injectors earlier today and it still does the same thing. All the injectors are firing cause i loosened them all while it was runnin and listened to em. And when i loosened them the knock might sometimes go away for a second or too but come right back. i put a fuel can right underneith the mechanical fuel pump and sucked fuel from there and elimated the lines runnin to the tank, so they cant be bad. And i did the same thing with the return lines. When i bought the motor the idle was turned up a little and i turned it down and it started doin the knocking. The ip pump on it is a reman pump but it was on there when i bought the engine and i assumed it was good. I did turn it up almost 2 flats. I dont know if that would affect it any tho. But heres the thing... i took the ip pump off the engine and the water pump and everything because it was way advanced when i bought it to make it run. So i took everthin off and made sure all the timing gears were lined up and i put it back together and set it where it was supposed to be and it wouldnt run. So i advanced it back to where it was before and it ran great. It idled and everything for a week or so. Then one day i drove it to the next town over and it did the knocking thing again. ( it started doin it when goin down a hill in neutral at idle) and i saw an o ring on the return lines was leakin. so i replaced it and now i got the knocking sound again. So i figured its either got to be taking air in somewheres between the mechanical fuel pump to the injectors( without leakin fuel) or its gotta be a bad ip pump. It did have a lot of junk in the filter when i changed it but i wanted to see what yall say before i start pricing ip pumps. cause maybe theres somethin i overlooked. thanks for any help yall.
!! Sorry. I just saw the "new injectors" in your post. Don't know if it will suck air in the fuel system since it's under pressure BUT it can suck air in the intake manifold. Could be bad intake gasket,cracked fitting,ect. Do you have access to a vacuum gauge? I would do a vacuum test on it. Not sure what acceptable vacuum should be but I know someone here would know. {AGNEM,ICANFIXALL,OLDBULL8,ect.} If low,erratic vacuum you have a leak somewhere. Let us know.
