Wolfer
I was testing fuses in panel under the hood on my 94 idi turbo f-350 cc and I noticed the abs light is flashing. Never thought much about it as I was working on lights to my car hauler. When I decided to move the truck I started it and it would not shift of park. Could I have blown a fuse or relay? I see no shift rods under the hood does it shift electronically.I am in my yard crossed my driveway but am dead in the water I sure could use some help. The shift handle will not move to reverse or any other gear like the shift linkage is froze up. I read a brake light fuse may have blown or a brake light switch if broken will not let the shifter move. any ideas? (fixed it was a blown brake light fuse #13 in dash fuse panel top sideways center 15 amp.)
