Badassford23
Why I'm towing a car and
trailer should I turn the od off or should I leave it on it a 92 f250 351 in it
Are you trying to burn up a transmission? Towing in OD at that low of an RPM is going to cause way to much heat into the trans. The small bit of mpg gain is not worth the wear and tear of shifting and heat will cause on the trans while towing. Beside the OP has a 351 gas engine and will probably need the extra RPMs for towing anyways.Leave it on all the time unless it starts to hunt when towing, except going up hill and you loose speed and it wants to down shift. Your wasteing gas (fuel) by shutting it off at stop lights , I make mine shift into OD at 37 to 40 MPH whenever I can city driving, just let up for a second, it'll shift into OD.
This is kind of a butt dyno thing, if the truck feels "comfortable" pulling the load, basically doesn't feel like it's about ready to down shift, then you can run OD. I'd only let it run in OD once up to speed. If in doubt, just turn it off, if you're only towing a small distance, the mpg difference isn't going to matter.So I should just leave it on in till the truck needs it like going up hills and towing heavy loads like the off should not be lite up is that rite
I don't even care to run OD in town when empty, more shifting and TQ locking/unlocking putting more heat and wear into the trans.
Yes, this is why the manual lock-up switch is a popular conversion.You do as you please.
The torque converter locks up when shifting from 2nd to 3rd on an E4OD. ....... the TC lockup is direct drive in 3rd gear.
