Tire Wear & Alignment questions
Brad S.
NW IA
Checked my tires recently and noticed my front tires are starting to wear a little uneven.
The drivers side tire is wearing on the inside rib and the passenger side tire is wearing on the outside rib.
The type of wear is the same on each tire, every other "lug" is wore a little.
Did a little bit of net research and I'll ask this.
If you were standing in front, the front tires would both be tilted to the passenger side???:dunno
Drivers side has negative camber and passenger side has positive camber???:dunno
Granted its not bad yet, but I can feel it when I run my hand across the "lugs".
I'm gonna rotate soon, back tires are ok.
Thanks all.
olsen726
