Tire size question.
93f250idi
strokin
cadiz ky
First to the mods if this needs to be moved feel free to do so.
Second what does a 305/70/17 tire compare to in like a 33" tire or like a 35"? Looking at a set for my f150 and need to know how big they are.
crashnzuk
West Sacramento CA
You can also look up the exact tire you are looking at on Tirerack.com or similar and click on the specs for that tire. It will tell you all you need to know. FYI, different manufacturers tires are different sizes even though the size marked on the sidewall is the same. If you are dealing with a tight fit, check the info for the exact tire you want.
Travis..
BrannonB
