Tell me about transfer tanks....
mu2bdriver
CT
Late to the party on this but I have a 25 gal aluminum tank mounted beneath my toolbox. It has a ball valve with a line that goes directly to the front tank. I used a double hose barb connector, drilled a hole in the tank, and put JB Weld where the fitting met the tank. I know my tank leaks at the far top of the sender so this was an experiment I was happy to try and if I had to replace the tank, so be it. No pump, just gravity feed, and it's lasted about 8 months without any leaks or problems. Works great and now I have 50% more range.
Sent from my iPad using Tapatalk
Clb
Another old truck
nannyfornia
So in case on one mentioned this' factor in the added weight for braking power!
I ran a early obs stroke with a 125 gal for filling equipment in the field, fill it go fuel rig and proceed, once it was not emptied, left full at quittin time 'and the drive home was fun( up in the mountains headed to the valley) do the math.
mu2bdriver
CT
Decent shape? What's it made out of? Could be a great deal if it's in acceptable shape.
Clb
Another old truck
nannyfornia
The dinger is the condition inside and everything about the pump.
Seems like a good price given the discription.???
dented73
