HammerDown
So I thought I'd go after that center u-joint...because it's original from 1988.
I gotta wonder what the Fu*k Ford was thinking when they designed the IFS 4x4 drive line on my 1988.
Just to service two little things such as the Stub-Shaft oil seal and u-Joint both wheels and related items have to come off..BOTH...axles need to come out and THEN the Transfer-Case drive shaft...THEN...Carrier housing (my poor back) must be pulled just to gain access to one stinking little SOB (snap ring) that then allows the Stub Axle to be removed for service.
*** Ford!
Several years back I replaced both outboard u-joints so at least the Spindles should come out semi easy.
*This might just wait till spring.
![Cookoo cookoo cookoo](/styles/default/xenforo/smilies/cookoo.gif)
*** Ford!
![Cussing -cuss -cuss](/styles/default/xenforo/smilies/cussing.gif)
