Sterling Axles
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I found a 10.25, 4.10 LS that was rebuilt for next to nothing. Can I put dually wheels on these hubs? I know if you try this on a pickup, the inside wheels will contact the springs.
I would be putting the SRW axle under a 1997 cab and chassis with dual wheels on the SRW axle. The wheels won't hit the springs because the frame is narrower than a pickup.
If this won't work, what about putting DRW hubs on the SRW axle? Would this be any different?
LCAM-01XA
my very own hell
SRW axle with dually wheels will work just fine on a cab-chassis truck. Just make sure the studs are long enough for the two wheels and the nuts...
Goofyexponent
Mentally Unstable..
10-4 on the studs, and trust me....I know ALL about the spring perches being different widths lol. I thought it would be a direct drop in, but the measurements are WAY different. I have to get 2.5" spring pads and re-locate them in on the axle.
