Steering gear
pafixitman
Westminster, MD
Does anybody know if a steering gear from a 5.4l 2001 E350 will replace my '93 F350? This is what the seller said.
97-03 Excursion Super Duty Truck Steering Gear
Out of a 5,4l,str,e350.4 bolt cover,o-ring hose fitting.
this will fit:
:Excursion '00-01 Power Steering; Tag SPA-JN
:Excursion '02 Power Steering; thru 5/02, Tag SPA-JN
:F250SD '99 Power Steering; from 3/99, 4x2, Tag SPA-JN
:F250SD '99 Power Steering; thru 2/99
:F250SD '00-01 Power Steering; 4x2, Tag SPA-JN
:F350SD '99 Power Steering; from 3/99, 4x2, Tag SPA-JN
:F350SD '99 Power Steering; thru 2/99
:F350SD '00-01 Power Steering; 4x2, Tag SPA-JN
:F450SD '99 Power Steering; from 3/99, 4x2, Tag SPA-JN
:F450SD '99 Power Steering; thru 2/99
:F450SD '00-01 Power Steering; 4x2, Tag SPA-JN
:F550SD '99 Power Steering; from 3/99, 4x2, Tag SPA-JN
:F550SD '99 Power Steering; thru 2/99
:F550SD '00-01 Power Steering; 4x2, Tag SPA-JN
:Ford F250 Pickup '97 Power Steering; over 8500 GVW, 4 bolt cover & o-ring hose
: fittings
:Ford F350 Pickup '97 Power Steering; 4 bolt cover & o-ring hose fittings
:Ford F450 Pickup '97 Power Steering; 4 bolt cover & o-ring hose fittings
:Ford Van '97-01 Power Steering; exc. E150; under 4200 lb front/GAWR, (Tag SPA-
: JN)
:Ford Van '97-04 Power Steering; E150
:Ford Van '02-03 Power Steering; E250, E350 and E450, under 4200 lb front/GAWR,
: (Tag SPA-JN)
:Ford Van '04 Power Steering; E250, under 4200 lb front/GAWR, (Tag SPA-JN)
:Ford Van '04 Power Steering; E350, exc. 6.0L; under 4200 lb front/GAWR, (Tag S
: PA-JN)
Thanls
I'm without my reference books here. but instinct tell me '97MY is the cut-off on the pickups. Not sure about vans. I know they are still using non-metric stuff on the vans, but I have no proof or experience on the steering gear fit.
pafixitman
Westminster, MD
Thanks TC. He has MY '97 as a cut off on the vans, so I bet you are correct on the trucks and vans. For $30 it would have been a good deal!
