Squirrelly turn signals
SKimballC
Portland OR
Here's a weird one. I noticed a couple weeks ago that my turn signal indicators on the dash have been prooooolonged, so on the way home tonight I finally cared enough to look at the turn signals and they are a bit erratic though functional. When I first hit'em, they will go at their normal clip, then after a couple flashes will stay on for a second and a half between pauses.
What gives? Besides gremlins.
rubberfish
Langley B.C.
Can you swap the flasher thingy with the one
for the 4way flashers? See if there's any changes?
adrianspeeder
USAF C-17 Avionics
Dover AFB / Harrisburg PA
First check would be to see if the 4ways behave normally. If so, you got a bad flasher unit for the directionals in the fuse panel. One buck at any parts store will get ya fixed up as the 4way flasher is a PITA to get to for a swap test.
Adrianspeeder
SKimballC
Portland OR
Ah, good and easy advice for a worn-out dummy. Yep, the 4-ways are fine so I'll pick up a new flasher thingamajig on the way in tomorrow. Thanks guys.
Alleycat
