runnig.tail light trailer wont work rest work fine (brakelight,right,left light)
Tim1
bc,canada
I have question about trailer running/tail light , somehow i cant understand how it works, I have trailer brakes,left right and brake light working but running/tail light have no power to it at rear trailer plug. i checked all the fuses and they are all good. where is the trailer light from plug go intro to I tried to follow the wire but I cant find it ? and does it have fuse ? (i checked also all fuses on the hood and they are all good as well )
my truck light are working fine. thanks a lot for your help
siegler
Seattle, Washington
What truck do you have?
Do you get 12 volts to your trailer plug (assuming your dealing with 6 or 7 pin wiring)
I just went through the same thing. Ended up being a fusable link next to the passenger side battery (on a 90 or 91 truck, may be different on other years)
Year of truck is important, along with are you using the factory tow harness or is it spliced into the factory truck rear light wiring for the trailer?
Tim1
bc,canada
Thanks a lot for all your help, mine truck is 7.3 turbo 1994 single cab xt longbox. yes I deal with 6 plug and brown/white line cable doesn't have 12 volt, its super hard to track down that cable all the way to the front so where is that cable go intro to ?
Tim1
bc,canada
where is this fuse located ? I dont see anything thanks
DaveBen
Ukiah, Ca
Tim1, please fill out your signature, by going to the SETTINGS at the very top, right hand side of the HOME page. Add your truck and where you live, in general. This will help all of us.
siegler
Seattle, Washington
Your 1994 doesn't use fusable links like earlier trucks. Fuse D in the fuse box in the engine compartment is for your marker lights. The relay for the marker lights is also in that box, that could be bad too.
Tim1
bc,canada
I checked all the fuses there and they all in good shape, how do you test relay, what do you mean by markers light ? thanks a lot
siegler
Seattle, Washington
If the fuse is good, you get 12 volts to the relay socket, but no 12 volts to the trailer plug when the running lights for the truck are on, I would be tempted to just replace the relay. I think they are pretty cheap.
Tim1
bc,canada
which relay is it ? thanks
Tim1
bc,canada
Check your light switch for burned terminals
Sent from my LG-D850 using Tapatalk
you mean the one inside the cab ? so I have to take plastic behind steering off and then look behind there ? or do you mean other kind of switch ? thanks
direwulf23
Botkingburg (NCen), AR
In the cab, yes. The actual light switch that you use to turn your headlights/ running lights on.
siegler
Seattle, Washington
Unfortunately, I'm unsure which one is which in the box, I haven't been inside of a 1992+ engine compartment fuse box. I have only been going off the wiring diagrams.....
The middle relay is the horn relay, the trailer marker light relay and the fuel pump relay are on either side of the horn relay. This is by looking at the diagram, not the actual box....
