Im replacing my right rear upper shock mount. Got a replacement from Doorman, happy to see it uses bolts. So I cut the heads off the old bolts or rivets (I cant tell, rust) on the outside of the frame with a wheel, and grind it flat. Then I was expecting to force the bolts/rivets through using a hammer and 1/4" punch. Well, im using a 5 lb hammer and none of the 3 are moving one bit. Im hitting them as hard as I can with a 1 hand hammer, horizontally.
Is there some trick to this? Please tell me the factory mounts arent welded on there. All I can see on the inside of the frame is a big triangular chunk of rust.
