LCAM-01XA
3.55 gears, like yours. If they weren't the same I wouldn't have mentioned anything as whatever numbers we see would have been irrelevant to your situation.What's your rear axle gearing?
Hmmm. 285/75 tires. 3.55 gears. 70 mph is just a whisker over 2000 on the tach. Speedometer accuracy checked by GPS and found to be PDC
Same tire size, at 2100 RPMs we get 62mph (GPS-confirmed), so yes, you running 65 at 2250 sounds legit. 70 at 2500 is also about right. Our truck has the ZF junk as well.
