FordGuy100
So....when you get your A/C system done the evac the system to get all the moisture out. Basically they pull a vacuum on it.
Would it be totally crazy to use a stock vacuum pump, rig it up so that it has the right hose end on it (might be hard?), and use it to evac the system?
Making the hose would be a real PITA, but, would it work
? Vacuum pumps can be had cheap at a pick and pull, and those fancy electric ones are at least $100. And I'm almost willing to bet that a stock vacuum pump idling would pull a faster vacuum.
Basically just have a spare vacuum pump laying around, with the right hose on it. Swap it on, which takes 5 minutes. Connect hose, and let the truck idle for half hour maybe an hour. Take the hose off, and whabam, there you have it.
Whatcha think?
? Vacuum pumps can be had cheap at a pick and pull, and those fancy electric ones are at least $100. And I'm almost willing to bet that a stock vacuum pump idling would pull a faster vacuum. Basically just have a spare vacuum pump laying around, with the right hose on it. Swap it on, which takes 5 minutes. Connect hose, and let the truck idle for half hour maybe an hour. Take the hose off, and whabam, there you have it.
Whatcha think?
