PS Fluid
Dsl_Dog_Treat
Decatur,MI
Possibility of the return line rubbing against the pump was what cause mine to go out on the Beef. Spent time and money rebuilding the seals and didn't fix the proble until I filled th pump back up. Then :eek: all the fresh fluid went back on the ground. Easy fix just hard to spot on these beasts. :mad:
160k87F250
not rocket science
York, PA
Could be comming from the steering box, either the pitman arm seal or the input shaft seal.
John
