punkmechanic
diesel tech
I am in Butte Montana and now have a bit of a problem. I was pulling the hill just east of town on I-90 and overheated. To make things worse when I went to push the clutch pedal in to pull off, it went straight to the floor and stayed.
After it cooled down I looked under the hood and found that the line for the clutch blistered and popped from the manifold heat (pulling the hill the egt's were at 900 and the temp was at the upper end of normal).
I got coolant in it and all the water from my cooler and it started and ran with no bubbles. I started it while in first and managed to get it rolling and up and over the big hill/small mountain and into the town of Butte.
If anyone is in the area and has a spare line or could lend a hand putting one on I could use it. There is an O'Riley autoparts down the street (Im in the best western) and Im gonna see if they have the line tommorow but I am not getting my hopes up.
thanks,
Justin
my cell is 407-403-4221 if anyone is around.
thanks,
Justin
. I would also loosen the allen screw on the bottom and stay up top for a minute and let the brake fluid go through the clutch line, then refill it and then go under it and do all the above. Good luck with it
