Parts help please
wmoguy
Colorado
Two separate questions here
1. I have an ATS pyro and boost gauge that came with the trucks I think I will reuse. Does anyone know where I can get the pyro lead and the boost tube hose and manifold fittings?
2. I bought a used ATS turbo kit off here. I know its missing a few things but not totally sure what all. Does anyone have a link to a parts list for the complete kit which might include pics too?
TIA guys this site is awesome!
The pyro gage is most likely a type K meter, ATS, Autometer and others have the thermocouple probe with different length wires, better to go to ATS if the meter has a number on it. You cannot cut the wire to length as it is matched to the meter.
To mount, drill a hole in the exhaust manifold at #8 cyl., you can either tap the hole,1/4" NPT or there is a banding mount that holds it in a 1/4" hole.
As far as the hose for the boost gage any hardware has tubing to do that, just have to get the right size to fit the fitting you use at the turbo and on back of meter, get the black nylon tubing, it don't kink.
You would have to go to ATS for the turbo parts. Just Google ATS.
hesutton
The Anti-Anderson
Bowling Green, KY
HERE is the illustrated parts list. Look at it very carefully and see what you are missing. There will be parts that are easily found else where and other parts will be ATS only. Hate to say it, but ATS doesn't have a good reputation for helping folks out espically with older turbo systems. Good luck with the install.;Sweet
Heath
