It works now, it dosnt shift as hard as I thought it would, the drilled holes are right down the middle of the of the recomended sizes, but its a solid shift at any rate. The torque converter isnt locking up, I'm guessing the crappy plug on the harness might be the culprit.
DANG!! your having wayyyyy toooo much fun!!! aint nothing more irratating,,than a trans malfunction!!.clean the pins with contact cleaner,,in both of the plugs. that may help it,,but then again, you may have to replace the plug end..
