Most I know, myself included, run 15W40 of one flavor or another. Don't ask what brand as that will start a small skirmish, something similar to Iwo Jima...
Nope, not if it's diesel rated but it will probably start a little harder when cold and probably very hard in the winter. Curious why you want to do that.
I run 15w-40 Rotella T in the IDI and 5w-40 Rotella T synthetic in the PSD.
Yup...I found what you did Roboto, but the oil samples didn't indicate that it caused any problems I didn't already have. It was a very slight difference like 9-10psi with the 30wt and 12-14 psi with the 15/40. The 15w40 acts like a 15wt cold and a 40wt hot.
