Note that I said UP TO 20%.......... not that it IS ALWAYS 20%. I'm not just pulling this out of my butt, that is from BlackStone. I can tell you that the lifters hold a surprising volume of oil long after draining the block, the oil pump holds oil, there is a good volume of oil trapped at the top of the heads as well. The oil cooler holds a lot more oil than you'd think after draining. The turbo (if so equiped) will hold oil in it's lines and center section.
Anyway, my point wasn't to start a debate on how much oil resides in the engine after drainage, the point was to remind folks that regardless of how you drain your oil during a change, there is a significant amount you can't and won't get out of the engine without a complete teardown.
Heath
Heath
