No A/C Wide shallow radiator switch to narrow deep
cahner
New Mexico
Before I pull my radiator and start soldering on the tank can the no A/C wide radiator be swapped for the narrow deeper radiator?
Thanks,
Casey
cpdenton
Truck needs paint.
Conway AR
It can, if you swap the radiator support too. It has a deeper lower hoop to clear the radiator. Your truck, because it was originally a gasser, probably doesn't have the deep core support, which is why the wide, short radiator was used.
chris142
SoCal
That non ac radiator is a rare one. I think I have seen 2 in my lifetime. 1800radiator used to offer a new one but we have not used them in a while
I bet that the 460 radiator #1451 would work fine.
cahner
New Mexico
I dont really want to mess with radiator support and then a new shroud. I bought the current one from 1800Radiator in 2009, they are warrantying the seeping upper tank. That is better than I could have hoped for.
You are right it is rare. When I did my swap from 460 I left that radiator in and it was fine running empty. With any load it would get way to hot quick. That is when I found the non AC rad and used it.
Thanks,
Casey
funnyman06
Coventry, RI
My 85 has dealer installed AC and the wide radiator. Id love to switch to the AC one if i had the pieces available but ill probably just buy another off rock auto.
attachment.php
cahner
New Mexico
1800radiator will match their price and deliver to your door the same day with lifetime warranty.
RustyNail351
