Hello friends, Im trying to order all some tie rods for my 2wd 1991 f350 cc 7.3. the outer tie rod ends have a ton of slop in them, but id rather replace everything all at once, so it all ages together. Im confused between these two:
http://www.summitracing.com/parts/mog-ds1138t/overview/make/ford/model/f-350/year/1991
and
http://www.summitracing.com/parts/mog-ds1073/overview/make/ford/model/f-350/year/1991
logic tells me i need the one that fits the crewcab/bent end?
also, do i need 1 or two outer tie rod ends (i believe i only need 1 for the driver side, as that long one already has a tie rod end for the passenger side)
finally, i see theyres some much cheaper options by Mevotech listed here, question-will they hold up to normal/non offroad use for 6 moths?
http://www.summitracing.com/search/...ar/1991/part-type/tie-rod-ends/drivetrain/rwd
i will be going 4wd within 6 months, but the slop is bad enough that I NEED to replace the components for my safety and others.
Any help please?
and
Any help please?
basically looking to replace all of this. from my understadning I need 3 individual parts, or is the yellow pitman arm 2 individual pieces?
