new guy in ny with a stuck 4x4 shifter and ...
briang
vestal ny
hey guys great forum
1st i got the truck i bought going with much help from this forum, so thanks
the truck is a 92 f350 7.3 non turbo, i will put some pics up soon.she needs some body work and paint being a new york truck
4x4 shifter will not move into 4 high
linkage is all good, nothing cracked, bit of rust. but i can only move the shifter 1/4" or so. i sprayed with pb blaster. but is there anything else i should look at
is it ok to have someone pull the shifter and tap the linkage a bit, or is that asking for trouble
also, how hard to change the key cylinder in a tilt wheel standard, key still works
can i just follow what i got off here and put a screwdriver in the detent pull out and replace, is it that easy?
thanks to everyone who posts how to's, ive learned a bunch from all
Brian
briang
vestal ny
is it the plunger inside the housing, where the rubber boots are, that gets hung up or is it the linkage?
thanks for the replys so far
Diesel_brad
Dunce
gilbert pa
Here is a better pic of another one i fixed.
It actually gets froze in 2 spots. Where the linkage bolts to the steel t-case bracket it seizes and will not pivot. And also the "plunger" in side the cast aluminum seizes and will not move up and down to allow you by the detent. Both places there is a grease fitting, they seize
briang
vestal ny
diesel brad, appreciate the pics
im gonna try taking the boots off while on the truck and see if i can get it freed up before winter, then take apart next year and put the greese fittings in.
thanks guys
Bashby
Charles Town WV
If it wont go into 4hi, it is stuck at the pivot where the big torx bolt is in the pic, you could pop the linkage loose (chock wheels, set brake) and see if the linkage is whats stuck or if its in the transfer case, but it's most likely the linkage.
briang
vestal ny
ok, i got the bolts broke loose to remove the shift unit
but i am having some trouble removing the plastic bushing on the linkage to get the unit out of the truck, see pic
i dont want to pry to hard, is there something i am missing or just use force
i thought that would be the easy part
can you buy just the plastic bushing, if i grind it out? or do i need to make one
guys were rite, froze up at the pivot point, when i get it out i will put the grease fittings in
hopefully it will go into 4x4 when all installed again
Diesel_brad
Dunce
gilbert pa
I would NOT pry on it. Spray w your choice of lube and use channel locks to get it off, by putting the lower jaw on the steel linkage and the top jaw on the pin that the bushing goes on. When you squeeze the pliers it will act like a puller
gdhillon
PG...Canada
mine only moves up about 1/4'' to 4 hi to...it seems to work. its 4lo i have problems getting into
briang
vestal ny
i may have been overstating a bit with 1/4",
now that i got it apart, i see that it follows a certain shift pattern
i guess it wouldnt even budge, because at a 1/4" movement you would be in
4h
im gonna put the greese fittings in and give her a whirl
were starting to get some wet snow here in upstste ny, and i live on a big hill
fingers crossed 4x4 works
by the way, the ignition cylinder was a breeze
thanks for all the help
gunz
Yukon Oklahoma
I took my shifter linkage apart, Blasted adn gre3ased everything. Seems to move much easier with longer thrw now.
crispy74
