need some help
93f250idi
strokin
cadiz ky
so i got my transmision swapped, everything went pretty smooth untill now. after reinstalling everything, it wont turn over by the key. you can jump the fender solinoid and it fires right up. something in the ignition is not letting it get power to the top terminal on the solinoid. i thought it might be the neutral saftey switch, but it still wont turn over (by the key) in neutral. only other thing i can think of is the ignition module thing under the dash. i have a spare im gonna swap on in the morning.
is there any thing else i need to check?
trackspeeder
Stone crusher.
North Branford. CT
Recheck the Transmission Range Sensor. Make sure it's lined up. Also take a good look at the connector. Make sure the pins are not damaged.
93f250idi
strokin
cadiz ky
pins are fine, thats why we changed it. the old sesnor was caked with dirt in the connector. its lined up as far as i can tell. shifts threw all posistions fine when moving the shifter
trackspeeder
Stone crusher.
North Branford. CT
When you changed the sensor, did you swap the plug too.
If you did recheck the pin locations. That will cause your no start issue.
